05 GSXR -
Went to start it ,Battery dead-Will not start with a jump. Can someone help, I dont want to take it to the dealer and and have to wait. Any one have this happen.
The last time I saw this the person put the bike in park mode by turing the ley past lock. This leaves some of the lights on draining the battery.
If you say it will not start with a jump sounds like an interlok issue. Check the interlock conections and make sure they are tight.
push start it....should work, wont be easy, but it will work
When u say wont start with a jump, do u mean nothen still has power (no lights nothen). If so check the fuses and connections.
If if still cranks but no strart, what u usen to jump it with?
Make sure u re-charge the battery in your bike too, or get a new one.
D
kill switch....on or off ?
Ignition interlock switch for the ignition circuit. The engine can only be started...
Tranny in neutral & clutch is disengaged,or
Tranny in gear, side stand is fully up and clutch disengaged.
hope its something simple
