It’s ben awhile, since I had a 600, I’m not 100% sure on the side fairing holes to frame, but you’ll need the sides, front, headlight and the fairing stay as well.
I can buy new fairings. Honestly just wanna know if the headlights can be swapped easily. Or if it’ll be a wiring issue
Don't know what "headlights" refers to, the bulbs or the housings? A quick look indicates that the K2 1000 has two side by side H4 bulbs while the K4 600 has a H7 high above an H4 high/low. Everything is very different.
Wiring should be the same if it uses different bulbs you can get bulb adapters but fitting the actual headlight unit would be a major pain in the ass as its completely different shape. If you do manage to do it tho I would like to see the pics 👍
