Help w/ \'04 600 Track Setup
The first trackday of the season was last Saturday - I installed a set of 208GPA's and left the my suspension the same from the previous year when I ran street tires. I've read that you need to raise the rear 4-7mm to acount for the new tire diameter.
Now here's my question: When going down the straights, my front end felt very unstable and twitchy - By raising the rear, will that stabilize the front tire? or do i need to adjust the front suspension as well?
Re: Help w/ \'04 600 Track Setup
the 208 gp rear is taller than your street tires-which raised the rear & made the bike feel unstable-if you want to regain stability-raise your forks to where they are flush w/ the top triple & see how that feels-if its too stable & hard to turn in-drop the forks 2mm at a time until its feels good
thanks sweeney - my next track day is on the 15th, so i will give it a try.
i'm also going to change out the oil in my dampner with a little heavier weight. hopefully that will prevent a potential tankslapper.
Here is your "R"
I run gpa's 180 rear and my suspension is 6.5mm rear lift and the front forks are 7mm of silver part sticking out of the top triple clamp. I love this set up. Traxxion front forks and stock shock.
