I stripped the oil pan at the drainplug hole. Is there a way to helicoil or retap and use a oversize drainplug? If so what size plug, and thread pitch or helicoil size etc.? Is there a kit somewhere that would include all the parts to repair?
Its for a 2000 GSXR750
Thanks in advance
Keith
Tractionless
Here is your "R"
Just take off your old drain plug take it to the auto parts store and ask for 1mm over size extruded/self taper bolt. Follow the instructions and your set.
I used a 1/2" 2 size up self tapping oil drainplug from Advance Autoparts. I have just one more question. When I change the oil the next time should I switch over to the 1/2" 2 size up non self tapping bolt as I see the package says "use only with stripped oil pans"
Thanks
Keith
Tractionless
i am thinking of opening a new post to ask this but before that maybe someone entering here can help me.
what is the torque of the oil drain plug for a gsx 600 '2003?
i have found gsx1000 2k but i dont think is the same. 23Nm says in the manual of this bike
can anyone help me? thanks
