Hi everyone, help needed.
I have just taken off the right hand side engine casing on my 99 600 srad (as you sit on the bike) to get it painted.
A. Is this the generator cover?
B. Should there be any oil behind it as a small ammount came out of mine?
C. If their should be oil, what type, how much and how do you put it in?
its engine oil..i doubt if you lost enough
to be of concern..check the sight glass..
with the bike level..
Cheers spongebob, do you know if it should be in there or shall I put it back together dry?
doOd...the oil will go where it needs to when the engine is running, fire it off,
let it run a couple minutes, check the oil again..if you lost a couple
tablespoons full of oil..dont sweat it..
to answer you question, put that fucker back together "dry".. you cant and
wouldnt want to add oil there anyway..thats what the oil fill cap is for..
buy a service manual..study it, ill come back at a later date and ask you
a few questions......
hrrrrrr then m8ty...
