1 - 11 of 11 Posts
i was riding my K5 home from work last night and all of a sudder the instruments stopped working, the gauges dont work, the turnsignals dont work and the taillight is off
the headlight works and the bike rides fine
if i put it in parking light mode with the key out everything is fine
what is the problem???
Check the harness behind the gauge cluster. Maybe it came loose.
Fuses are on the left side behind the fairing, just above and in front of the front sprocket cover. Will probably have to at least loosen the fairing in the back.
yeah this happened to me at the track last time i was at VIR - figured it was a short from pullin my headlight/turn signal connectors and not tapin em up. The fuses sure a bitch to get to compared to bein under the seat or up by the insturment cluster
fuses are under your seat and behind your right front fairing. if you poped the guage cluster one, its behind the fairing. they generally give you one of each amp spare fuse.
1 - 11 of 11 Posts
