Hi all
I have got my bike running now and took it out and it has a big lag at 3-4000rpm (carbies are 36mm cv's with std needle with clip in the centre,147.5 main, 32.5 pilot and k&n dual pods filters) i the then droped the clip one groove with no change so i took it back to the way carbs where set up with the air box (std needle, 117.5 mains, 37.5 pilot) but i forgot to change clip pos but it is not as bad now could anyone offer some help as it will be a couple of weeks before it goes on the dyno now cause i strained the lower back while pusing it on to trailer and like to get it as close as possible so i can at least go for a ride, i will get some pics up soon
Sounds like you leaned out the main circuit and got some improvement...so keep leaning it out to see if it gets better. I don't know at what rpm the main circuit takes over, but it is probably right around your problem spot. Good luck
