Hello,
Today when I turned on my gsxr1000 after 3 months, a lot of oil began to drip from the side of the water pump, I am quite concerned because the oil loss was quite continuous and apparently no crack is visible.
Is it necessary to open the whole engine to solve that oil leak?
Thanks
Your pics show the leak from the joint between the middle and upper cases. That's not a good place for a leak as fixing a leak there will involve splitting the crankcase, not just between the lower and middle but also the middle and upper. However that's an unlikely place for a leak to suddenly appear and it's likely coming from somewhere else. There are dye kits that involve adding dye to the oil and inspecting with an ultraviolet light. You really ought to use one of those. Your first pic suggests that the engine ought to be cleaned first.
Water pump oil leaks can come from two places. There's an O-ring around the nose of the pump where it inserts into the crankcase. It apparently can harden and be a source for a leak. In that case the leak will run down the side of the crankcase and maybe the outside of the pump. There's also an oil seal inside the nose for the impeller shaft. If it leaks, oil will come out the drain hole in the underside of the nose.
Air currents can move leaked oil around on the engine. Your leak could also be coming from the valve cover gasket, CMP sensor, breather cover gasket, breather hose, clutch push rod, transmission drive shaft, or even the airbox where the breather hose attaches.
Discussion Starter · #6 ·
Hello
I have found the oil leak, it was not from the crankcase, it is from the head gasket...
It is not a standard head gasket since the bike has a turbo and has a cometic jc0001 gasket, 0.06.
It's weird that he's gone...
Replacing a head gasket is a lot simpler than splitting the crankcase, though there's bound to be complications on a turbo bike. The crankcase looks a lot cleaner in your most recent pics than in the first. The breather cover vent doesn't have a hose. I hope that you have one and route the fumes into a catch can or the intake.
