1 - 13 of 13 Posts
Re: HELP - Can\'t find reverse!?
Originally posted by Chainrash:
Its contagious!!!! Mine did the same thing at lunch!!!!! Damn Suzuki Trannys. Its almost as bad as the power window module on the wife's 600. Hasnt worked since day one!!!!
Discussion Starter · #2 ·
<font size="2" face="Verdana, Arial">Chainrash- Check the fuse box, the power window/doorlock/stereo/windshield wiper fuse wasn't plugged in all the way on mine....
You have to turn the key to lock, click the brake three times, turn it on and use the front brake as the clutch, it will go backwards like a champ!!
thats weird. mine is like a 4wheeler, you have to pull the brake in and push the "R" button down, then shift one down past first, then let off the brake and voila you have reverse.
I can't seem to find reverse on my motorcycle. I tried twisting the throttle the other direction but it just makes this strange cracking noise. Do you think this is still covered under warranty?
-jay
Nah, you guys have it all wrong.... Reverse only works on the Australian models because of the whole reverse polarity thing they've got going on down there... Kinda like their toilets. Damn Aussie bastids, always knew they were up to something
· Premium Member
No No No No.. everyone is wrong. On the left handlebar, there is a switch, if it's in the middle, you wont go anywhere. click to the right, that's foward. And yup, you guessed it, to the left is reverse. you must make sure you leave it in the direction you want to go
1 - 13 of 13 Posts
