1 - 9 of 9 Posts
Please help ! I have a 99 GSXR 600 that starts bucking "HARD" while acceleration. It happens on all gears from 1500-5000rpm. I only run 93 octane gas and is completely stock. The bike starts and idles perfectly. Only under load that this hard bucking happens. Any ideas?
My first thought is "Any other MOds ??", then realised u said it's stock.
Possible causes :
- Worn chain [tight spots = irregular tension].
- Carbies out of synch, rough low rpm response.
KaTz
[ 10-24-2002, 11:18 PM: Message edited by: KaTz ]
It might also be a matter of getting your mixture right. It sounds like it's running rich when you open up the throttle. Maybe a new airfilter as well?
Maybe not the right direction, but this is what I think anyway!!
Good luck!
How many miles?? Maybe it is time to put a new (or just clean) your air filter. Plugs... How about a valve adjustment??
I just replaced the chain and sprockets 2 weeks ago and they look fine. The Hard bucking doesn't happen when I get on the gas. It happens when I am already on the throttle and going through the RPM.
Maybe one of the new plugs has gone bad... I would pull them and look at each one... Make sure they are all good... Then think about a carb sync...
Look at the plugs, all the vaccume hoses and the clamps that hold your carbs on. Also check your fuel filters. Could even be electrical.
just a shot in the dark but something kinda like that happened to me once.
my positive battery cable had worked its way loose, its started and ran then on a harder accel from a stop it would buck but i never noticed the power going out.
next time i tried to start it at school, it had power but didnt start. i was fustrated and hit my seat and the power blanked out slightly, so i though hmm...
so check the battery cables, wire brush them while your at it.
1 - 9 of 9 Posts
