I've tried basically everything and now, nothing! It was hesitant when I first got the bike thinking it was something simple. I replaced the stator, rectifier, fuel pump, spark plugs, coil packs, and injectors and now it won't even stay running! I can start it up and it'll have a really bad idle and die right after starting... I've tried adjusting the to and nothing. It has good fuel pressure. It used to run and I just couldn't put it past half throttle or it would bogg out but now I can't even give it throttle and it doesn't even stay running! Any advice would help!
Here is your "R"
Sounds like you have a fueling problem, those hose from the pump to the rail many times gets kinked and restricts flow, I would check that. When you lower the tank keep an eye on how it rests.
Next I would pull the fuel pump out and clean the filter screens on the pump.
This makes since as it is progressively getting worst, due to more crap getting clogged.
About this Discussion
3 Participants
Ibidu1
Full Forum Listing
