Damn, do people trouble shoot anymore?
1.)Check fuses, relay(if there is one) then bulbs(not likley they both burnt out, but stranger things have happend)
2.)Check your wiring, pull off your plastic, make sure nothing came loose, disconnected....usually will fix it at this point.
Still wont come on?
2.)Being electrical, its all the same, grab your meter(or test light), find the wiring diagram on the web somewhere and follow the wire and check for voltage as you go.
