Hello. I have a 2015 gsxr 600. I did a hid conversion. 35w ballast with 6000k bulb. Both low and high beam. Once in awhile when I turn the key to the on position I hear what sounds like the ballast shorting out and it doesn't come on. If I turn the key on and off a few times sometimes it'll come on. I changed the headlight fuse from a 10 amp to a 30amp thinking maybe the 10 wasn't strong enough but I still have the problem. My question is now is there a relay I need to replace or resistor to get this hid to work like it should? I already went through one hid ballast. Really don't want to go through another. Thanks in advance
