I was riding yesterday and about halfway through my ride I realized that I did not see my headlight shining on the back of a vans doors....I found a good place to pull over and checked the light. I dont think it is the bulb because the high beam doesn't work either...All my other lights work on the bike, tailights, signals, gauges etc... What do you think it could be? Fuse...Wiring? Any suggestions would be great.
thanks in advance
I had an issue with the low beam fuse blowing out but that was from a Hyper White bulb heating up. I seen a lot of post here to check the wire harness on the left side of the bike because the fairing rubs there and also check in the high/low beam switch on your hand controls.
check these 3 things. 1. fuse (obviously) 2. wireing harness especially at the connectors, they tend to get coroded inside the connectors (happened to me) and 3. check the wireing and also inside your switch housing on the bars. hope this helps you bro, im sure it will.
