Hi, I have gsxr 600 k4, and the headlight was not working, I changed the bulb and all was good, but when I next started it, it blown again and I do not know how to find the cause of this.
can anyone help if point me in the right direction?
The alternator and/or the R/R might be failing. Pay really close attention to the system voltage. I hope you have a multimeter.
Has the way that the bulb is mounted changed from OEM? Are you sure that the bulb blew rather than that there's a bad electrical connection? I guess you could try another bulb or bulb manufacturer but a faulty bulb seems unlikely.
· Premium Member
gonna need a multi meter and such, check for grounds and chaffed wires, startwitha visual, unplug all connectors and inspect, clean and pack.. youtube can walk you through leaks and grounds, continuity so forth, funny its not blowing fuses instead, is there anything off right at the housing?
