Yes, you may need to space a few areas. I only spaced at the bolt near were the set valve was and it does not touch anywere. Now ever one is going to chime in and tell you why and why not to do it! Ha But it does flow more (on the street might lose some down low, with out mapping) but it's big weight savings.
It fits, and you will be happy with it. As said above, make sure you have enough clearance everywhere. If not, simply shim the fairings out a little.
