Hi, sorry about the dramatic thread title, my name is Andy, and about 2 months ago I bought a 2nd hand 2010 Hayabusa, somehing I had wanted for years and years as you can imagine. Then from literally week one, had massive problem with the Fuel, Temp, Revs and MPH guage/meter/needles banging to full, then bouncing back to zero, display cutting out, clock starting again at 1:00, and even a 5 mile journey or more wrecked by the entire dashboard cutting out, (eventhough the engine appeared to still work).
I tried new battery, heavy duty too, in the hope that one of the intenal cells on the old one was faulty, but to no avail, and often even with no key in, the needles on all meters are flicking to the right then left, almost to the point where I worry if they will bend or warp.
Here are a few photos, to help, in the 4th image you can just make out the needles literally flicking from left to right and banging on the edge of the dial, and in some cases when key is unplugged too, and in other cases, dial readings bounce to MAX then MIN, with all lights on, in the case of image 4.
Dont suppose anyone has solved this annoying problem, I dont even look forward to drive anymore, and the original seller, fair enough, wants me to ride it to him, but its a distance, and I just dont trust the bike at all, I can just see it abandoned between here and kingdom come.
I have read about tight wiring harnesses pulling on wires and connectors, and possible corroded connectors etc
Would you know if there are any 'you tube videos' which even tell you how to take the sides off for access to the harnesses, all I have been able to do so far was change the battery and for me that was quite a fete too lol. Hope you can help, take care. ANDY
