Going to try to descibe this as best as I can.
So First off I havenew wired and brand new 3 ohm ignition coils.
It all started with not having spark to plugs 1+4 tracked it all down, tested the coils figured id be all good. Put the new coils and wires on now I still had no spark to 1-4. I swapped the wires to the coils and checked spark then didnt have spark to 2-3. So Im at the point I dont think its my coil and might be my cdi or pulse generator.
Does anyone have any other opinions on what could be happening?
Discussion Starter #2
Just as an update, tested both of my coils and pulse generator. All of the resistance readings read within spec. I looked through my wiring for anything that could be grounding and found nothing. So definitely pointing towards the cdi now. Anybody have a say on ifi should go for a dyna 2000 or just get another stock cdi? This is a strictly drag race only bike just as an fyi.
