1 - 16 of 16 Posts
Had the K5 dyno\'d lastnight...
1300 miles...slip-on Two Brothers M2.
158.99
No printout...Done at a local bikenight...Now I need PC3r to get a little more from her.
Re: Had the K5 dyno\'d lastnight...
not bad.. the slipon probably isnt doing much for you without a pc but you should break 160 with a pc and map. and maybe a couple more once she loosens up.
Has anyone posted a dyno plot with stock and modifed charts?
Won't fitting a TRE mean the gear indicator reads 6th all the time?
i believe jeffw got that worked out, but i could be wrong.
No he didn't. There was someone else though that had a setup that was aparently working. Although it wasn't the stock gear indicator, they used another one that read the gear off of something separate than the ECU.
Discussion Starter · #11 ·
I'd be curious to know if this has been worked out. I actually use that quite a bit...
clova,
do you know what kind of dyno they used to dyno your bike and what was the room temp. thanks
Discussion Starter · #14 ·
clova,
It was a dynojet, atleast those are the labels that were all over it. Also, it was hot as hell in the room with fans blowing. It was a trailer..One of those kinda like semi trailers that you see at drag strips. You may have heard of the guy. His name is Joe Morasco...Well known dragger.
I know joe personnelly....Get the mapp from him.....He does all my runs ...His shop is located in heath ,ohio.....
158.99
little off subject but how is the fit, quality and sound of your two bros? any suggestions were to get it at a good price? thanks
1 - 16 of 16 Posts
