1 - 2 of 2 Posts
Hi All!
Went to start up today, and I can hear a clicking/sucking sound coming from what sounds like directly below the fuel tank. This begins when the bike receives power.
On my last checkup, it was noted that a fault code was P1769 (Fuel Pump) also along with Steering Damper P1769 and Exhaust Control Valve.
The technician said these kind of codes can commonly be thrown and weren't anything to worry about - however a month and a bit later I again have a fault code and this noise.
Any thoughts on what this could be? I thought it may be the ECV actuator but it sounds like the noise is coming higher up, right below the fuel tank / above the engine.
Video of this issue happening:
L1 750
Kinda sounds like exhaust valve motor & cables.
Not much work just to lift the tank and point a light in there while it's making the noise.
1 - 2 of 2 Posts
