Hey guys im looking at the 1k motor and radiator assembly along with the oil cooler. How do thise mount up?
I have the upper mounts of the radiator mounted to the frame. When i swing the radiator backward the lower holes on it do not line up with the upper holes on the oil cooler.
Should they? Anyone have pictures of the brackets etc?
have you resolved you issue?
i am doing the same thing here, pm'ed you with a questions or two.
i have a hardcopy 2000 gsxr750 manual, 01-03 gsxr750 manual on cd and a 2001 manual on cd so what year bike do you have?
well i have the hardcopy manuals for the 750. I know how the radiator mounts on a 750, thats no problem.
The problem is i don't know how the radiator mounts to the oil cooler on the 01-02 GSXR1000
The motor in the bike is a 01 1k motor.
Do you have any links to a 1k manual.
ok, i have a 2000 gsxr750 frame, radiator in the garage. also have a 2001 gsxr1000 engine, radiator, oil cooler.
looks like the top of the 1000 radiator has 2 mount tabs with gromits that connect to the bike frame. botom of the radiator has a center mount tab w/ gromet, this is bolted to a bracket going to the engine. there are 2 more bottom tabs w/o gromets that bolt to the oil cooler and finally the oil cooler has a center tabe (somewhat right of center) on its bottom that bolts to a bracket mounted on the engine.
