my 7/11 project came to a halt today, nearly finished, put the chain on and noticed that it shifts into first or neutral, nto no availothing else, it wont go into second gear, no click, nothing
I tried rotating the tire while manipulating the shifter lever to no avail
I pulled off the clutch cover and removed everything to expose the ratchet shifting mechanism but see nothing odd, looks like i may have to split the cases.....I hope I can source parts
so who is our resident gixxer trans expert
Discussion Starter #2
for your inspection, or viewing pleasure... In the third picture you can see the pin that the spring acts upon, what is the best way to get this out easily..... its hard to get to the bolt head
568812
568813
568814
You do not have to remove that pin, and the selector shafts can stay in place to split the cases. If you remove the sump and flip the engine you should be able to see why the gearbox does not shift.
tore the pan off, found the problem, it wasnt in the trans, the shifter linkage was binding ever so slightly, the rod end mount on the pedal was just barely touching the bracket, fixed, and a new pen gasket, the pan looked great other than a tiny amount of what I believe are clutch fibers/particles
