A week ago I filled my tank, then traveled 4-500m down the road and motor cut out and will not restart, lights, blinkers, horn and dash all turn on and working switches doing the same.
The electronic sound when you turn key to On or put stand up is not working since bike stopped motor not starting starter generator is working and battery fully charged
03 Gsxr1000
Still could be a battery. Or even the connectors. Also check under the left side rear of tail section to see if wires are burnt at the connection for regulator/ rectifier
Administrator
Wrong section ... moving thread
Turn the ignition and engine stop switch on and measure the voltage at the O/W lead on the dealer mode connector. It should be battery voltage. If it isn't, and given that the horn & lights work, the problem might be with the engine stop switch. See the diagram on 9-12 of the service manual. I assume that you've checked the fuses.
