Hi guys,
New to the forum here but been around bikes for over a decade.. tinkering and modifying my two TRX850, breaking or fixing & selling bikes and generally keeping on top of maintenance on my daily rides.
During the first lock down (March/April 2020) I decided to build a 1996 GSXR 750 carby from the ground up for track use only and have done two track days on so far.. first one was a bit epic due to a few bolts & screws falling off
+ a duff battery. The second one was awesome & stress free without a single spanner or screwdriver being used but I noticed two issues however..
1. The bike is running rather hot (between 95/105 degree celsius).. first day was hot-ish with 25/27 celsius but second day was fresher at around 18/20 celsius. Rad, hoses, thermostat etc are stock, they look clean & in fair condition for the age, coolant is new (standard Putoline product which I use on all my bikes). I've checked for air bubbles in the system after the first track day.. leaning the bike from left to right, squeezing hoses etc. yet still ran hot on the second track day. Is it normal? What am I missing?
2. Second issue is around the voltage & charge whilst running.. I have a volt meter display connected to the battery which shows an accurate 12.8V for the battery when the engine is off (new battery & voltage cross checked with a volt meter). When the engine is running & idling, the voltmeter display approx 13/13.2 volts charging however, when running, the voltage drops to between 12.5/12.7 volts at around 7000rpm. Electrics isn't my forte but I would expect the voltage should keep in the 13 volts + whilst riding.. what should I start checking/testing to get to the bottom of the issue?
For info, I am based in the UK (SW London) and the track in question is Brands Hatch.
Cheers,
Adrien
Cheers,
Adrien
