Hi, boys and girls, just joined,,,,,, and need some help.
I have just had a k4 600 2004 dumped on me by my son, been standing about 10 years after the usual spill.
It currently has no, clocks, fairing or light.
Question is, will it go without any of these items.
At the moment I’ve tried a battery on it but seems to be no life in fuel pump.
Spins over, all leads other than clocks are connected.
So far I assume pump or relay?.
Any other tips or pointers will be gratefully received and tried.
Thanks, Andrew..
Yes it should run without those. Do the fuel volume test to check the pump directly. Work out from there.
Thanks geek,
That’s pipe off hooked up to jug, I assume?, did see that in past threads and was on my future list after I had some life out of it.
If nothing, seized pump or relay?, ( obviously checked fuses), assume I strip pump out of tank for a look.
Not having any diagrams at moment, a pic’ of which relay terminals are which, for testing if it’s any good, would be handy.
Discussion Starter #5 (Edited)
So far...... Pump was seized, took it to bits, now works off battery but not harness.
Have permanent live at fuel relay block.
Is it possible for ignition side of side stand relay to fail and not flasher?.
Fun continues with this bike has 2 acumen small boxes and large box/siren? marked Suzuki under tail, some kind of alarm system, may be an issue.
Only have one original key which I am not sure if this is immobiliser, have no fob...
Your ECU is probably not getting any power. The clocks would make checking for that easier, but try to locate a capped connector near the ECU with either an Orange/Green or an Orange/White lead and see if you have +12V there. Also try to get a service manual; you're going to need it.
Discussion Starter #7 (Edited)
IMG_0841.jpeg Hi all after a bit of a break on it, I now have the Gsxr 600 k4 running, turned out to be seized fuel pump and no power to ecu due to alarm fuse issue.
Next question is I know nothing about the Acumen alarm in case I can’t post pic’, I have square Suzuki flip key with 3 button and a spare plain black key, need to know what the buttons do or an instruction link, bleeps, once presume off?, twice presume on?, not sure if other key overrides alarm?,
There are 2 small boxes wired in and main big alarm box on rear subframe
Thanks, Andrew..
