Hi,
Does anyone has an issue with the Rpm meter that always stuck at 2k?( Even when not on yet.)
When turning on, and revving, the Rpm meter will not go pass 2.5k.
Is it fixable for my case?
And any idea which part had gone wrong?
The RPM dial is a stepper motor. I had one go bad and my RPM dial was just jumpy. Contact Scott over at bluegauges.com. He's really good and might be able to help you. You might have to buy a busted cluster off eBay and send it to him to use for parts.
When you turn the key on, does it do a full sweep?
Hi, thanks for the reply.
I'm currently in Singapore and I heard that not all cluster from other countries will match with my bike.
When turning on the key, it will be jumpy between 2k to 2.5k. Will never go pass 2.5k.
If it cannot be repaired, do you think getting a aftermarket RPM indicator is good?
