Wonder if any one as any advice for me .
I’ve changed my coolant for the first time on my gsxr I’ve refilled it back up with ready mixed prestone coolant when Filled it back up it only taken 2 litres to be come full is and my first ride out my bike is getting hotter quicker and and staying around 105 c
How much coolant should go in to my bike and could I have air in the rad
Thanks for your help.... yes I did follow the instructions the bike is running perfectly and it’s cooling down fine , but it won’t take the 2.7 L that the manual Requires it’s taken about 2L and it’s full dose this mean I still have a air block ?
The capacity can be misleading. Unless you take the engine apart, there's still going to be water trapped inside and not drained. For example, the oil cooler and associated lines. That probably makes up for that 0.7 liters.
