1 - 16 of 16 Posts
Hello,i come from Denmark,and i Got a gsxr1000 k8,Can a rear shock fit from the neaver gsxr1000 dobbelt rr year 2017-2020,they are cheap on eBay,and i Think it woud be a great option on my bike,the k8 rear chock is too hard for me.
574287
The spring is losen all it Can,and the compound is also sorten all it Can both ways,
The backend is sommetimes steppen,hven i drive it hard in the corners
That sounds like a big step. There are issues like c-c length. Have you tried a softer spring?
No i hawent try a softer spring,the new shock from the 17-20 model i the rr version,
Is ligtyear better than mine,that also therfore i ask,are there somebody in This Forum
knows if it fit.🤗
The new shock from the 17-20 model will have the same STD spring as your current bike. SO, no difference.
Lighter/softer spring will work on your bike or Suspension Tuning done buy a specialist.
Discussion Starter #7
I have done alot of suspension tuning on my bikes,withaut saying i am an expert
I Can set a bike op,but i know my bike is Way to stiff in the rearend,my weigt is 85 kg
So i Will get a softer spring,hvere Can i get that spring,thanks for help🤗
85kg?
The factory shock should be just right for your weight
I'd suggest checking if the shock doesn't stick, or that the linksystem hasn't seized
Spring pre-load for your K8. The manual says, Shock Length, 156.0mm (hardest) to 166.0mm (softest).
Outside these measurements the shock won't work the way it was designed to.
As Mb says, Definitely need to check/ re-grease swing-arm and linkage on your 12 year old GIXXER. (y)
An easy check is :- with wheel off and shock out, feel the movement and the play in the swingarm.
Racetech's website has lots of info.
Discussion Starter #11
Hven it stands on the sidestand,and i Press on Seat,it goes smohtly and Nice,its the same on the stand,but its to hard for me.
If you're capable setting up suspension, but the shock is still too hard, the only things left are either
-Personal preference (but you really don't want to decrease shock stiffness below a certain point that handling becomes dangerous)
-Mechanical function, in which case, the shock (or linkage) simply needs refurbishing/replacement
I'm 65 kg on a K5, didn't have trouble with the rear shock with my weight
The front OTOH had trouble with sticktion, giving me sore wrists no matter how I tried to change settings
Using a different shock from another model may remove your complaints, but you won't know if you can get it to fit and what it will do to the suspension geometry/load
Discussion Starter #13
[/QUit sometimes steppen a little bit widt the rear end,hven i drive it hard in the corners,
I also had a 06 Kawasaki z1000 that done that,but i find a cheap øhlins shock,and now every is ok,but i cant find a cheap øhlins shock in Europe,and in the us,i shall pay huge taxes for shock and also taxes for shipping cost
Discussion Starter #14
Discussion Starter #16
1 - 16 of 16 Posts
