1 - 2 of 2 Posts
Hi Guys,
Since i bought my motor second hand, i've no neutral light, no gear indication (only 0) and no rev light.
What i tried:
Kick stand down (motor wont start) so kickstand sensor works
replaced the gear position sensor.
Still the same, if i hold down the left reset button and turn the key, i should be able to set the rev limiter light. But that doesnt work.
I can switch between modes!.
What is happening any idea?
Thanks
Discussion Starter #2
Problem is found, its the circuit board behind the gauges that had some oxidation.
1 - 2 of 2 Posts
