GSX-R750F Sub Frame
802 views 3 replies 3 participants last post by  Karitane Pete
#1 ·
Hi,
Got some welding repairs to do to my subframe. One side has had a previous repair prior to my ownership but has cracked again. I also think my subframe is bent. The pics probably explain it better. Can anybody tell me if the subframe is a straight piece fo ally front to back or is the bend in my frame correct?
Cheers,
Mike
#4 ·
mount the frame up on a table and make sure the tail is inline with the rest of the frame, mine wasn't, had to bend it side ways about 15mm.
Run a string line across the top of the frame and you should see where its out.
and by the way the other side will be cracked too, mine was.
