Hello
I'm new to this forum so first off i'll introduce myself. I'm Sam, 21 years old and bought myself a GSX-R 1100 from 1994.
The bike wont start so i took it apart to find the problem, it wont spark.
I've read several posts here to find a solution but nothing helps :/
So far i checked:
-Signal generator (172 Ohm) and when cranking 0.7V output
-Primary coil (2.7 Ohm)
-Secundary coil (37K Ohm)
Also changed:
-Coils
-Spark plugs
-CDI
-Battery
When cranking the coils drop from 12V to 9V
Checked all the wires and none are damaged and the connectors all fine.
So far all seems fine to me...
Am i not seeing something? Hope you guys can help me :)
I had thst problem twice on my 96. Once it was signal generator, needed an extra resistor in igniton wiring. Other time it was the ignition switch
