GSX-R 1000k8 not starting
120 Views 1 Reply 2 Participants Last post by  BillV
after turning the key, the display does not show 0, the fuel pump does not turn on and does not start. what could be the reason?
1 - 2 of 2 Posts
It sounds like there's no power to the ECM. Have you checked the fuses? Measure the voltage between the O/W and B/W leads on the dealer mode connector. It should be at battery voltage. If not check the kill switch. I assume it won't crank. Is that right?
1 - 2 of 2 Posts
