1 - 18 of 18 Posts
Hi guys!
Have running this issue since bike came to us. It leaks a bit or "sweat", but as you see, it is around oil. I have been replacing the washer two times and putting teflon tape around the thread - doesent keep the oil away. I did not found the right Nm for the plug either.
Some experts doubt there might be just a bit microfissure in block, but if that's right, how do you fix that?
Do you know anything similar issues or what you recommend to do? I haven't been concerned because the bike is not leaking down any oil, but it still bothers me from time to time.
Appreciate your help!
-Daniel
Flash photography Automotive tire Gas Light bulb Auto part
GSX-R750
Just to be certain, I would clean that entire area and the plug and check again. Sometimes things run down from areas you wouldn't expect!
I would use a gentle plastic brush and some engine degreaser or simple green and just brush off all the dirt around that whole area. Run the motor again and watch for a new drip/weep, and touch or smell it to confirm it is oil or coolant.
In my experience, drain plugs don't usually ever leak, especially after changing the washer like you mentioned. I'd say clean it up and check again and show us the results.
Hope this helps.
-Mike
+1 on that. It could be a leaking valve cover or many other places in between. No offense but you may be so fixated on the plug that you're ignoring the real source. Here's an old but relevant post. If the leak really is at the plug, a suitably sized Dowty or Stat-O-Seal sealing washer might cure the problem.
I'm with my fellow posters above
Especially since it looks rather wet above the plug, at that distance, I'd expect that plug to visually be squirting oil upward
Firstly, thank you - all of you!
Secondly, I need to clarify: I have been investigate the leaking spot for two winter seasons. And yes of course I have cleaned that area before very clearly many times. So 100% sure is the leaking source.
And yes those plugs typically not leak.
I would like to know if you have anything similar experiences.
Thanks @BillV for your seals advice! I will keep that in mind.
if that plug is leaking why is there oil/wetness above the plug?
pull the plastics, nose and panels, wash that engine CLEAN top to bottom..
then run it, up to temp, search for leaks up front, hold RPMs to 3000 or so if its not leaking off idle, still no leak gonna have to crack it open several times to build pressure and get the oil thin..
I can see oil up on the cylinder overhang and the wind pressure wont blow it up that high and cover it completely like that just from a slow less than drip leak off that plug..
my guess/bet is its coming from the valve cover at a decent clip, how often do you have to top off?
Discussion Starter · #7 ·
Thanks for the message. It does not leak from valve cover or anywhere above. As I mentioned earlier, I have inspected that very precisely in two winter seasons with many many cleaning and heating cycles. Only oil what leaks quite rarely comes from that plug.
Top off only when checking valve clearance (24tkm).
GSX-R750
It sounds like you're pretty sure this is the source of the leak.
If that is true, I would be pretty picky about reinstalling a sealing washer on it, and making sure it is clean. It's just like cleaning a drain bolt surface. Use Q-tips or scotchbrite or something to make sure you get all of the gunk out of the orifice prior to installing a new gasket washer, and clean the bolt head as well.
When I do any engine work, the parts I take off at least get a thorough top to bottom cleaning before going back on, just to ensure that there is zero dirt, dust, debris, or other bits that could ruin the motor. So if it was me, I would take the bolt out, clean it up with a tiny wire wheel on my dremel to scrape out any buildup in the threads or head, wash the bolt in solvent with a toothbrush, rinse it all off, install a new gasket washer, wipe out the threads on the engine and thoroughly scrub the mating/sealing surface with paper towels or scotchbrite if needed to get it perfectly clean, and then torque it down.
In my book, the only way to guarantee a leak fix is to first do those steps, and don't cut any of those corners. Some dirt or rocks on the threads or in the block or stuck to the washer can prevent it from sealing right, and then damage the sealing surface next time you take it off, making it hard to ever seal ever again.
In fact, for gasket surfaces on engine parts, I usually wet-sand the engine cover or part with 800-1000 grit paper on a glass or machined surface, and it makes them absolutely perfect to seal up. Of course, doesn't really apply to sealing bolts, but you get the idea.
If you did all that and it still leaks, I'd suggest replacing the bolt, and then like Bill said, maybe look into a new sealing option.
Hope this helps, I believe you if you say you've cleaned it all super well and are certain it is coming from here.
Folks, the wetness above the bolt can be due to the wind from riding the bike, this is the front lower portion of the engine, and thus why the drip pattern may look odd. I wouldn't be so quick to assume OP is not capable of finding the leak source, lol.
-Mike
welp this might sound freeking weird cuz it is, I watch that mechanic dood that posts pics of oddities coming through automotive shops, compilations .. "customer states" something like that?
dood had a brake master cylinder on a car forget the rig where the end of it pin holes formed and fluid was leaking out when you pumped the brakes, no chit
any way you can mount a full time cam up front where it can catch the action? clean her spotless then see where it comes from? if not perform the steps I layed out, strip her down, clean it, run it and wait.. see where its coming from, you wont be the first guy to chase down a leak
Discussion Starter · #11 ·
-Mike
Hi Mike and thank you very much for a great post!
The leaking source as I mentioned earlier is 103% right.
What confuses me a bit is that friends over here hardly believe my leaking source.
I’m thinking replacing the bolt and look after what you suggested.
Much appreciate! :)
-Daniel
Discussion Starter · #14 ·
Let us know how it goes!
-Mike
I tested a quick fix without removin the plug. Sealed it from outside with motor silicon. By noon today I went for a test ride - 120-150km in and outside the city. Occasionally hard driving, includin hitting rev limiter etc.
In the evening I checked the plug - no leaks whatsoever. :)
-Daniel
Tire Automotive tire Tread Motor vehicle Automotive lighting
If it works, it works. But all that suggests that either the sealing surface on the crankcase or the plug is damaged in a way that the copper washer won't seal.
Discussion Starter · #16 ·
Yep, I agree - obviously for some reason washer does not seal properly.
Now 2 weeks after I put the silicon, I saw just a minimal oil sweat at one spot of the bolt. The mystical thing about this whole leaking thing is - either the bike stands without using it or riding it, the amount of oil leak (very, very tiny amount) is kind of same.
As I wrote earlier, 100-150km hard driving did not get any leaks - now 2 weeks after been sitting I see very minium sweat there - and actually confirmed after touching the plug (mark on finger).
I already did an oil change, and I will ride whole next season with that quick fix. Will see if it slows down it a bit. :)
There's a thread here where I switched my drain plug to an aluminum plug with magnet and a Stat-O-Seal. I see about one drop leaking out every 3-6 months. I've since located a fairly high end NAS seal intended for aircraft usage but have yet to use it.
Discussion Starter · #18 ·
Ok, nice to know. But yeah, that very tiny sweat or droplet like 3-6months is nothing to worry about.
1 - 18 of 18 Posts
