1 - 13 of 13 Posts
The fact that it says "chec" on the dash leads me to think it is the kickstand switch.
kickstand is OK, kilswitch too. In service, no one knows where the problem is. I apologize for the translation, my English is poor.
"chec" indicates that is ecu isn't receiving any communication.
Check your stop/run switch, and your fuses as well.
stop/run switch is OK i have new wires and kickstand is disconnected. Maybe it does FUEL PUMP FAN SWITCH RELAY or Flasher relay...., but I dont know
There's a posibility that the various switches, esp. the kickstand switch test fine while the bike is stationary, but fail at certain circumstances, for instance due to bumps and a weak stand spring or due to resonance at certain rpms. It might be a good idea to try and isolate the switch entirely, by temporarily disconnecting it and jumping the wires manually. Just don't hack up the wiring in the process, be extra careful while riding and don't leave it like that permanently, if it works.
Discussion Starter #7
Kickstand is disconnect, but the wires are connected as if they stand functioned. The problem is somewhere in the circuit switching box, killswitch and relays fuel. How to proceed in removing the problem? Will be resolved through exchange relays?
I bet it's the fuel pump relay. I had the same issue with my K1 1000, changed the relay and it was all good.
Any news on the issue? I think I am having the same or similar issue.
^What are the symptoms when it dies? Does the cluster get power? What is displayed on the cluster's LCD panel. Are you in neutral and does the neutral light come on? Does the fuel pump prime?
Not the powers that be, not even close.
Check the two connectors going into the ECU and the ECU connector pins for corrosion.
Water can get in there from washing, or riding in the rain. I pulled mine out last year to inspect and there was significant corrosion, but not failing yet.
My 99 R1 corrosion went to far before I noticed, and had to buy new ECU.
1 - 13 of 13 Posts
