Hi all , I'm fairly new here and have had my gixer since the start of the summer . I have found a bit of a random toggle switch under the pillion seat which definately dont look standard ! I have traced the wiring back and gone through the wiring diagram which tells me it is the MODE SELECTION SWITCH , but the manual does not mention it anywhere else . Can anone shine some light on what it is and what it does , I am sort of thhinking it might have something to do with dealer fault codes or the like but i am only guessing lol . Any help will be much appreciated peeps cheers SIBO08
Flip the toggle with the ignition on. If it goes into C00, it's a dealer switch. It could also be linked to a power commander.
See 4-29, 4-33, and 7-5 and elsewhere in the service manual. That switch should connect to W/R and B/W leads.
