opk what i thought it was the starter but its the generator that is make werid noise when starting like a taping noise, clanking noise when its idels any ideas of whats the problem or how to fix it with out buying a new one? thanks!
I had a generator that started making a knocking noise so I disassembled it and found out the bearing went bad. I bought a rebuild kit from the dealer that came with new bearings & seals and that took care of the problem.
how much does it cost for one of those kits
younggixxer, one way to check the generator is to unplug it while the engine is running if the noise goes away most likely its the generator. I wish I could remember how much the rebiuld kit was but it was about 6 years ago.sorry
yes I agree it sounds like a bearing failing to me too
Andy
