1 - 2 of 2 Posts
Hello folks, I posted this on the 05/06 section but this may be a better fit. I've searched the forums with little result. I found on an someone doing this same swap but the OP never finished it.
I am looking for information on swapping the Gen 2 Hayabusa swingarm onto my 2005 GSXR 1000. I am looking to do this purely for drag racing. I believe the swingarm is a little longer, however I am mostly doing this to run the Gen 2 Pingel wheelie bar setup.
It appears the axle diameters are the same, does all the GSXR stuff slide in like the wheel and caliper mount? If so does the chain alignment stay correct?
One difference I do see is the swingarm bolts appear to be different diameters, is there a spacer kit available to run the smaller diameter GSXR bolt in the Busa arm? If not I have a lathe and will make them.
Thanks in advance.
Likes to race old junk.
Contact McIntosh and see if they have anything, otherwise it seems you're in a pretty good position to fab up whatever you need, to make it work.
1 - 2 of 2 Posts
