I'm putting my gear shifter back on my K5 and I am wondering what i need to do to align the shifter properly???
what should I look for if it's not aligned properly??
will it not shift into a certain gears?
any sounds it will make if it's mis-aligned?
Thanks alot guys for all the help.
Peace
~Andy
I wish I could bud, good luck.
I glanced through the manual and did not see anything regarding alignment.
Here is what I did what I took mine off and put it back on.
Re-installed the parts but did not fully tighten any of the bolts. I just made them finger snug.
Next shifted the shifter up and down and made sure it was not binding. With the bolts loose it was able to move around on the mounts allowing it to move into the position it wanted to be in. Once it was where it wanted to be and it was not binding I fully tightened it down
Next I adjusted shifter height and tightened the bolts. Tested with my boots.
Tightened all the bolts.
Sorry I could be more help.
