Hey guys. I have a K9 1K and the odometer water temp and gear indicator gauges don't work. It's not the cluster itself cause I tried another with the same results. Also the mode buttons don't work either. I've searched but found nothing. Any help is appreciated. Thanks.
Sent from Motorcycle.com App
Odometer or speedometer? If it's odometer then you have another problem with the cluster.
But you must be talking speedometer, since you tried another cluster with the same result.
The secondary wiring harness plug to the main wiring harness plug plug and cluster plug are your likely culprits.
