Did a search, didnt come up with much. I wrecked my bike about a month ago. I got the whole thing repainted. Anyway, I got LP flushmount signals front and rear, they work fine, but when I have the rights on the signal indicator on the guages doesnt come on. It works with the left turn signals on. Any ideas? Here's a pic with the bike finally back together.
yea i just had this problem recently. that assembly that holds the turn signal switch has three solder points for the turn signals. one ground and one for left and one for right. I took mine apart and my left side solder came apart. So i resoldereed it and it works fine now. Or you can check the yellow plug in the wiring harness. sometimes that is faulty. You can find this plug if you follow wires coming out of the turnsignal assembly to the wiring harness. Its the first plug.
