21 - 24 of 24 Posts
just on one end (the end above the stator side) and it's seldom and only cold starts. i will replace the fuel line and clamps and it should fix the problem.
Anyone know the actual ID (inside diameter) of that particular tube/line? Auto-Zone sells by the (3/16, 1/4 etc.) but usual size is "8" i believe on most sport bikes. can anyone confirm the gauge of that black fuel line?? thank you in advance!!
I realize this thread is shockingly old at this point - I have the same problem on my 2006 GSXR600. It even seems to be coming from the exact same place. Did you end up removing the entire assembly and replacing the hose? Did you get generic hose from an auto store?
As long as you get fuel rated hose, that's also rated to stand the psi on our bikes, you'll be good to go. Any auto parts store can get you squared away
21 - 24 of 24 Posts
