1 - 2 of 2 Posts
I have a 2000 marauder and can not locate the fuel pump relay. does this year have one? i'v been working on this bike for about a week and can't get it started. rebuild the carbs, replaced the fuel pump, replaced some fuel lines. need some help.
Don't know but, since it has carbs, the fuel pressure will be lower and I wouldn't be surprised if there was no relay. It may be quiet but you ought to hear the pump when it's running. Alternately use a voltmeter. The pump power probably runs from the ignition switch through a fuse. You could prime it to see if it will run briefly, which would tell if the ignition is OK.
You'll probably get a better response on a Marauder forum. See here.
1 - 2 of 2 Posts
