I've used the black fuel hose plenty of times, just make sure that you use the correct hose for the correct purpose. Some fuel lines are meant for external use only, and are not great for being inside the tank itself.
The fuel line is maintained as 43 psi. If it bursts you and, even worse, the bike could burn up. Use black hose rated for that service. It also needs to be kink resistant.
cool.....thank you. i did forget the PSI on hoses...which is very important. thanks again.
