Problems, change my exhaust system on my 01 GSXR 1000 to a Ti-froce slip on, now when I reach a range of 9000 rpms' during hard accelluration, gas seem to choke off. When I gradually roll on the throttle gas flows fine. I've checked the fuel line for cramps, throttle position sensor code at -COO in center. Ran with power commander USB connected and unconnected, K&N airfilter clean, tried three or four different maps, removed airbox an check to see if throttle bodies flap open when opening the throttle, working fine. I've tried everything I can think of and finally at the end of an rope
Fuel filter not letting enough gas by under hard acceleration....Makes since, but i'm not a mechanic and I didn't see that listed above...
Or maybe the fuel pump is acting up and not pumping enough gas at WOT?
Thanks for the input. I pulled the top fuel line off and turn the switch on, fuel flows out but I'am not sure if this telling me what I need to know, if the bike not at wide open throttle. The dealership close today for the holiday and can't speak with a Tech. I'am hoping one of my gixxer bro's with tech. knowledge or someone with prior problems can help me out, by responding to this post
After all the trouble shooting done, It came down to dirty fuel Injectors, all four. Pulled off throttle bodies, removed all four Injectors sprayed with carb cleaner, problem solved.
good going....
Discussion Starter · #6 ·
One thing I've learn about having a motorcycle, is to learn everything about the up keep of your machine, It will save you a alot of out of pocket money, if your not afraid to be an hands on guy
