1 - 20 of 23 Posts
I got my bike new in dec 04, never really checked the tire pressures. but today I went to the gas station and found that the rear was set to spec @ 36 psi, but the front was 30...
i then added some air and set it to 36 Front 36 rear... and I noticed the ride was firmer
Do yourself a favour and purchase a nice digital pressure gauge of your own. Those ones at the stations get used/abused by so many people that they are rarely accurate. Also allows you to measure a true cold pressure vs the higher psi that will develop after just a few minutes of riding.
PM me for Brotection
Re: front tire only had 30 PSI from dealer on my 05 GSXR600?
I have a nice chromed brass analog guage that works pretty well, fits nicely in my tail section next to the tool kit. Tires lose a little air over time, after heat cycles, etc. It's not a bad idea to check your pressure regularly.
Cock Thumb, or Thumb Cock? You decide.
I run 31psi on the street at all times...
36 psi is asking to tuck the front.. 30-30 front and back on the street at all times.
If 36 makes it so easy to tuck the front why does the factory recomend it?
if you ride aggressively, 36 is too high, more prone to tuck the front. they recomend it to get the most life outta the tire, fuck a few hundred miles i want that shit to grip. The dunnie street tires arent the best out there, not a lot of feed back, they would just let loose. Much better experiecne riding pirelli's. you wont find one guy who has tires balled tot he edge front and back run anything over 32 psi even on a hot day.
36 HOLY CRAP your going to killl yourself.
30ish is where you want them. I've been running 30/31 for the past 3 bikes and 3 years. Its the best for road/track/wheelies
36 is high for the front...I run 31or 32 in front and 30 in the rear...try it out you'll be suprised it makes a big difference.
I just tried it out yesterday...it does make a big difference.
play around with it a bit, literally 2 psi will make a diff. if it was a colder morning id run like 28-29 up front, hot days 31-32. id usually run 1-2 psi higher in back. easier to control a bit of spin coming out of a corner the the front starting to slide. never had any problems mileage should not be a concern on a sport bike. i rather spend a extra few hundred a year on rubber than sliding down the road on my face.
Discussion Starter · #15 ·
Okay i went out and lowered my tire pressures to 31F 31 R
I hope the bike will ride, handle and perform better
I personally like the 36/36 factory suggested pressures. Turn in is much more responsive and it just wants to turn so much easier. Tucking the front is more a byproduct of not knowing how to corner properly than running factory settings. Slow in, fast out, front tire shouldn't complain at all. And for the track sure, lower them, they'll heat up and up the pressure too high if you run factory but the street is hardly the track, or shouldn't be.
wow broad spectrum. guess each of us will just have to spend more time riding to test out each psi setting between 30 and 40 to see what we like
1 - 20 of 23 Posts
