Ok guys (and gals), which manifolds are the best fit for a set of RS36's on my 86 1100, the stockers were pretty hard and I wasn't able to squeeze the carbs on there, so I went with a set of 92 750 manifolds as sugested by Rohm Performance.
They seem a little big with the 92 clamps, but fit tight with the 86 clamps. Is there a better fit for this setup or will these work?
The bikes still in peices, so I cant fire it up to see if she's sucking wind.
Thanks
Dave.
Discussion Starter · #6 ·
I just pulled the carbs and manifolds, and the numbers are as follows.
13110-1700
13120-1700
13130-1700
13140-1700
Does anyone know what these are off of?
The numbers Jay gave are close, but off by one digit, is he dislexic or are my manifolds just plain wrong? I have a feeling its the latter
Any more help would be greatly appreciated.
Thanks.
[ 07-11-2002, 06:39 PM: Message edited by: Tornado-rider ]
Tornado,
I used to have the smaller boots on my rs 38's and ended up replacing them with the larger boots. I think APE's part #'s are correct. Also, with the smaller boots, you had to lube them up to get the carbs on, but I noticed that after taking them on and off over time it stressed the boots and I developed a crack in the boot. Switched to the larger ones and have not had a problem since.
