On the fly updates:
It looks like there's some bracketry on the left side that would hold some relays or something. No idea what goes there, but the cleanest install would be with the subframe on the left. I can ziptie things in place later on, as long as I have the mount points for the rectifier, which is easiest to route to with the whatever bracket out of the way. I can also add that back later on if I want.
The rear cowl attaches with bolts in one location on either side. There are small holes under where the seat would mount that could probably ziptie the front of the rear cowl in place.
I think I'll trim the plastic from the set to the left in the above photo to tuck in well under the race cowl, and if I figure out what's supposed to be mounted to the relay bracket on the left later on, I'll add that from one of the other subframes.
Shit. I'm realizing I chose the plastic that doesn't have the bracket that holds the ecu in place.
