easter bunny said:
Can somebody do a cliffnotes on replacing various parts? Like why would you do a gold valve and not the gold rebound valve?)
I think that would be a cost vs. feel thing, as you would likely notice the improved feel of new compression valve/shimming more than the rebound.
[/QUOTE]Does a cartridge kit replace all the internals and what's the advantage over doing just the valves? [/QUOTE]
A cartridge takes a lot of guess work out of tuning as the cartridge maker can give you new shim stacks that they know will work for your application. I think the main advantage would be the improved adjustment range of the new Comp and Reb needles.
[/QUOTE]Do the seals and bushings need to be replaced (or is it at least a good idea to)?[/QUOTE]
I would, pretty cheap in all.
I'm re-doing my 05 750 forks this winter. I plan on putting in new springs, comp needles and reshimming the stock valves for better feel.
