There is a module you can install to tell the ECU you don't have the exhaust valve anymore. Costs around 30€. If the Fi light comes from that.
Depending on the year & model, there commonly is a way to turn the light off. You might try checking the instructions for Yoshimura headers for your bike. On some it can be done by removing a pin to the ECM and plugging the hole. On others a rotation limiter is installed on the servo in place of the pulley. There also are servo eliminators.
