So I just started my bike after being stored for the winter and now have a light on. The battery did die I charged it for a few days and its good now. Started the bike while i was putting seat on and i have this light now. I do have a PCv installed on it, could that be the issue? Between the truck the car and now this with the bike I'm ready to chain them together and drive them off a cliff. BTW its a 2009 GSXR 1000 with 3100 miles on it.
You will need to put the bike into dealer mode and tell us what code the ecu is throwing.
Ok will research how to do that. My 750 was easy i havent done much to this one at all.
Did you do the set valve delete yet? Mine was in storage and threw a code cuz the cables were acting up on the set valve assembly when I pulled the bike out after winter. Deleted all that garbage and pulled the ecu pin and no issues since. Also threw in a new set of plugs for good measure.
False alarm after letting the bike sit then jumping on it, its gone now. Oh well bullet dodged. Keep the shinny side up And be safe.
